Window relay
Power window relay is playing up have spare but can't find exact location?,can here clicking around centre console.
I'am going to change this first and see,if not the problem,I have another 944 issue:(:(:(:( My car is right hand drive 85/1 model,thanks |
Cheers ernie,found an earth fault in one door switch and fixed that,relay was warm to touch so replaced anyway,one job of many to tick of the list,thanks
Porschetub--I read your post, I too am having a window switch issue. This is a intermittent issue. Sometimes it works, sometimes it does'nt.
I removed the switches from the driver side door panel, and tested the voltage on both switch connectors, I had 11.3 volts. But the passenger side window will not move up or down, using the drivers side switch. I removed the passenger side switch from the door panel, and tested for voltage, there was none. I jiggled the wire loom that runs from the door to the door jam. Still no voltage. Any idea's? |
My switches have always been ok. Is your battery good and have you tried the tests with the engine running? Get back to me,cheers. |
| All times are GMT -8. The time now is 01:28 AM. |
