porschetub's Avatar
Window relay
Power window relay is playing up have spare but can't find exact location?,can here clicking around centre console.
I'am going to change this first and see,if not the problem,I have another 944 issue
My car is right hand drive 85/1 model,thanks
Old 10-11-2011, 12:35 PM
ernie9944's Avatar
It's under the dash on the driver side.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 10-11-2011, 02:35 PM
porschetub's Avatar
Cheers ernie,found an earth fault in one door switch and fixed that,relay was warm to touch so replaced anyway,one job of many to tick of the list,thanks
Old 10-11-2011, 04:06 PM
Porschetub--I read your post, I too am having a window switch issue. This is a intermittent issue. Sometimes it works, sometimes it does'nt.
I removed the switches from the driver side door panel, and tested the voltage on both switch connectors, I had 11.3 volts. But the passenger side window will not move up or down, using the drivers side switch.
I removed the passenger side switch from the door panel, and tested for voltage, there was none.
I jiggled the wire loom that runs from the door to the door jam. Still no voltage.
Any idea's?
Old 10-22-2011, 04:14 PM
porschetub's Avatar
Any idea's?
Check your door switches half way up the from the door hinges,you may have a poor earth there or the relay , mine our fine now after doing that.
My switches have always been ok.
Is your battery good and have you tried the tests with the engine running?
Get back to me,cheers.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 10-22-2011, 10:10 PM
