Mein Gott!
Panzer909's Avatar
Anyone ever try this to their AFM?
Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com
Was there any improvement after you tried this?
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 10-15-2011, 01:14 PM
Back from Beyond
Did this to my 83. Made throttle response smoother and was a fun evening of fixing. The trick is getting the AFM open without hurting anything. Be gentle and careful.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 10-15-2011, 01:19 PM
Mein Gott!
Panzer909's Avatar
Hehe - a fun evening of fixing....that's exactly what I was looking to do tonight in the garage
What did you end up doing to get through the sealed cover? Or more importantly, what did you use to seal it back up?
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 10-15-2011, 01:22 PM
Back from Beyond
Sliced around circumference with a sharp blade and gently pried it open with a screwdriver. Resealed afterward with black silicone, but I put the plastic top back on and THEN sealed the outside edge, just on the off-chance the electronics didn't like the silicone. I was lucky 'cause I had a spare to destroy getting it right. And yes, I DID destroy my spare...
All others GONE!
Old 10-15-2011, 01:28 PM
Mein Gott!
Panzer909's Avatar
Couldn't get the wiper angle right or back to normal on the first one?
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 10-15-2011, 01:32 PM
Back from Beyond
That wasn't it. I fractured the cover getting it off! Got excited, I guess...
All others GONE!
Old 10-15-2011, 01:51 PM
Proprietoristicly Refined
John_AZ's Avatar
HondaDustR did a video and a 2nd video down a bit in the post.
Air flow meter fix / refurb
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-15-2011, 03:40 PM
porschetub's Avatar
Wow that cameraman must have been tiny .
This is a standard fix I've done on vw and bmw afms,but its not for the ham-fisted,before you go cutting in to the cover clean the body out with afm spray cleaner then check the action of the air gate,if thats worn you need to look @ a exchange replacement.
Its not worth proceeding on the wiperboard fix if the rest no good.
Wee tip cutting off the lid sealer,cut upwards to free the join,carefully praise the cover all the way around not just by one cover,have't broken one with this method.
I friends been working on vws for years and his thrown heaps of faulty? afms away ,wasn't happy when I recently told him of the fixes possible
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 10-15-2011, 04:49 PM
Mein Gott!
Panzer909's Avatar
Well, what started this whole idea was when I was tinkering around earlier this week. I was cleaning engine bay contacts, plugs, and took the AFM off to inspect the door movement & clean.
Put everything back together and fired the car up. It barely started and was running horrible. Looked back under the hood and forget to plug the AFM connector back in
So anyways, plugged that back in and she started right back up. But wait....the car now had a bad miss at idle, bucking and serious backfire under heavy load. What da??? Disconnected and reconnected the battery, changed out spark plugs, cap, rotor and no change. Fuel filter is on its way. Don't know what I must have disturbed when I first started cleaning everything(?)
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 10-15-2011, 05:06 PM
John_AZ's Avatar
Did you plug the TPS connector back in correctly?
John
Old 10-15-2011, 05:18 PM
Mein Gott!
Panzer909's Avatar
The TPS? Didn't even touch that. It's in a tough spot on the S.
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 10-15-2011, 05:20 PM
On a late 85.5 AFM the plastic cover pops off relatively easily. I cleaned the contacts with an eraser, as described elsewhere on this forum or Clarks, and there was noticeable improvement. I reattached the cover with black RTV silicon 3-4 years ago and no problem to date.
I wonder if the extra wire provides the same boost as the MAF mod discussed extensively some months ago?
Old 10-15-2011, 06:43 PM
