Tool for torquing tube to bellhousing bolts?
How on earth do you get to the two top bolts on the torque tube?
I had to use a flexible ring wrench and all my might to get them off, but now I'm wondering how to torque them correctly when I'm ready to reinstall. There is no way I can get my torque wrench up there.
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 10-13-2011, 05:12 AM
That Guy
Techno Duck's Avatar
Flex joint, long extension and a flex head ratchet work. Personally i dont use a torque wrench on those, i just do it by feel.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-13-2011, 09:02 AM
White and Nerdy
Tervuren's Avatar
Take the distance of your leverage, say, its six inches, on a 31ft/lb bolt, then 62 lb's on a six inch lever is 31ft/lb's.
Like the post above, I sometimes estimate the body strength to exert a similar amount of force, then take a rough guess of how long my leverage is, and go for it.
You can practice such things with your torque wrench if you want, just put your hand short enough on it to represent the leverage you have with whatever wrench you are using, and get a feel for it.
Shadilay.
Old 10-13-2011, 10:47 AM
Thanks. I was thinking something like a crows foot would do it, but then the risk of rounding the head would be high.
Old 10-13-2011, 12:30 PM
porschetub's Avatar
I turn nuts and bolts for a living ,you just get to know by feel,I fitted my torque tube after fitting the bellhousing to the motor as I didn't have a clutch alignment tool.
This helps in another way because you don't have the tube in the way and you can tilt the motor downwards to give more room to work on the top bolts.
In short I just cranked the buggers up,cheers
Old 10-13-2011, 03:12 PM
