air flow meter questions
So I am testing my AFM and it does have 8volts going to the connector but once plugged into the AFM I have 0 volts. My Haynes manual say replace the AFM. My question is if I refurbish the AFM as per FRwilks instructions will it fix the problem?
you might recall that I have a starts but only runs two seconds deal going on.
Thanks to anyone who can help;
TJ
Old 10-13-2011, 01:54 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Rebuild it by "F.R. Wilks" (A good method). Have you been into it ? To see if the wiper foot is making contact, may be time to bend it ? Also check out the throttle position sensor for good contact - clean terminals,etc., or replace. Could be other things going on also - how long since the fuel filter has been changed out?
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-13-2011, 03:14 PM
