Sunroof
I probably sound like an idiot.. How on earth do you put the sunroof back on an 88 944. I took it off for the first time and now don't know how to get it back on. I got it back on the front but the arms at the rear won't go back in. Tue electrical part doesn't work anyways so i can't do anything about that.
Old 10-16-2011, 08:33 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Normally one would place the front of the Sun Roof into position first (Insert the wind deflector in front of the sun roof), then operate the up and down switch so the rear arms grab the roof and pull it down. With out any power you would have to go to the Sun Roof Motor (Left side of the rear hatch area, just behind the inner wheel well) and operate it manually. There should be a flat wrench located there to turn the Sun Roof Motor by hand, if no wrench get a socket of correct size and operate the motor with it manually.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-16-2011, 11:01 AM
Do you know which way to turn it? Because I've gone both ways and nothing
Old 10-16-2011, 01:05 PM
Pete R's Avatar
I did the same thing. The arms won't retract enough in the on position. Turn the key one click then operate the arms. they should go all the way in then
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 10-16-2011, 02:10 PM
It didn't work. The arms don't move at all
Old 10-16-2011, 04:02 PM
Pete R's Avatar
oh.. How did you get it out then? There's a safty button in the front of the sunroof that is depressed when it's properly installed. Is that depressing and there must be a fuse somewhere..that's all I know
Neon SRT4 track car
Old 10-16-2011, 07:06 PM
Garage Helper
Go to: Clark's Garage Home Page
Then click on Garage Shop Manual
Click on the "S" , for Sun Roof.
Go down to "Sunroof" and click on "Operation, Troubleshooting, and Repair".
Old 10-17-2011, 10:42 AM
racer's Avatar
It can be a finiky situation. In fact, this summer, I was able to remove the top but couldn't reinstall (sounds like your issue). Reason? a failed microswitch located where PeteR mentions. Once replaced, operation returned to normal.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-17-2011, 03:34 PM
