-   -   2.7 L engine specs and mods (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/637010-2-7-l-engine-specs-mods.html)
smokin_944 10-28-2011 05:44 AM
Gentlemen, I am on a quest for knowledge. I have 2 questions. 1.What makes a 2.7 L different than the 2.5 L? The bore? The stroke? 2. Can you use a 3.0 L crank in a 2.7 L engine? What happens to displacement?
9FF 10-28-2011 06:01 AM
2.5L is 100mm bore, 78.9mm stroke.
2.7 has the 3.0L bore of 104mm and the 2.5L stroke of 78.9mm
3.0L has 104mm bore and 88mm stroke.
A 3.0L crank in a 2.7L will make a 3.0L capacity. Also you can make a 2.8L using a 2.5L block with a 3.0L crank. You will obviously need the required rods and pistons to go with any change.
mwg968 04-24-2019 08:13 AM
Trying to get more info on this. I know it’s technically feasible but has anyone done it? What performance can be expected from a well setup 3.0 8V?
wildcat077 04-24-2019 09:58 AM
I went for a ride around Mosport with an instructor who has a well set up 944 with a 3.0l engine and i can honestly say it made my 2.5 N/A car feel like a turtle ...
It's a Canadian owned car , possibly built by Blaszack in Ontario ?
