smokin_944's Avatar
Porsche Crest 2.7 L engine specs and mods
Gentlemen, I am on a quest for knowledge. I have 2 questions. 1.What makes a 2.7 L different than the 2.5 L? The bore? The stroke? 2. Can you use a 3.0 L crank in a 2.7 L engine? What happens to displacement?
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 10-28-2011, 05:44 AM
9FF 9FF is offline
9FF's Avatar
2.5L is 100mm bore, 78.9mm stroke.
2.7 has the 3.0L bore of 104mm and the 2.5L stroke of 78.9mm
3.0L has 104mm bore and 88mm stroke.
A 3.0L crank in a 2.7L will make a 3.0L capacity. Also you can make a 2.8L using a 2.5L block with a 3.0L crank. You will obviously need the required rods and pistons to go with any change.
Old 10-28-2011, 06:01 AM
Trying to get more info on this. I know it’s technically feasible but has anyone done it? What performance can be expected from a well setup 3.0 8V?
Old 04-24-2019, 08:13 AM
Northern Motorhead
wildcat077's Avatar
I went for a ride around Mosport with an instructor who has a well set up 944 with a 3.0l engine and i can honestly say it made my 2.5 N/A car feel like a turtle ...
It's a Canadian owned car , possibly built by Blaszack in Ontario ?
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-24-2019, 09:58 AM
