racer951y's Avatar
Send a message via AIM to racer951y
speedo sender not installed right. maybe?
I took off my speedometer sender when I was taking out my transaxle but only the sender and not the part that screws into the transaxle. When I got it all back together I seem to not uave a working speedometer anymore. This is on my S2 with a 5 speed
Did I miss a proper way to reinstall the sender?
'82 928
'86 951(RIP)
'90 944 S2 Cab (RIP)
'92 911 C2
Old 11-02-2011, 12:23 AM
racer951y's Avatar
I just replaced the odometer gear and noticed that one of the wires to the speedo had its insulation rubbed off in a spot so I wrapped in electric tape and will see if that was the issue when I re-install the cluster.
'82 928
'86 951(RIP)
'92 911 C2
Old 11-08-2011, 12:29 PM
I am not using the speedo sensor on my trans so if you need one I'd cut you a deal if you 1) know how to remove it and 2) know how I can plug the hole.
Old 11-08-2011, 02:47 PM
