unindicted co-conspirator
looneybin's Avatar
high voltage issue
I've searched the forum, but haven't found any info that is exactly what my issue is.
Last week i had to put my battery on a charger because the interior light was left on and drained the battery - i didn't disconnect the cables when i hooked up the charger.
When i started the car, the voltage gauge is reading very high, not up to the red, but damn close.
Is it possible that i fried the voltage regulator/alternator by using the charger?
When i add load to the system (lights, turn signals etc) the needle does slightly drop, but it's still above 14
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 11-14-2011, 08:29 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
If you do not have any testing equipment take the alternator off and go to your nearest auto parts store and have it tested - it sounds like you fried the voltage regulator...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 11-14-2011, 10:20 AM
looneybin's Avatar
i have a multi tester, what would i be testing for? the actual voltage at the battery?
Old 11-14-2011, 10:47 AM
Garage Helper
Check at alternator for 13V. or slightly below at higher RPM's (3K plenty)
Old 11-14-2011, 11:28 AM
looneybin's Avatar
i'm getting 13.69 vdc at the battery at idle, the gauge was reading 14+
i also did the LED upgrade, could that be wacking out the voltage gauge?
I only replaced the 3 main bulbs, not any of the warning lights
Old 11-14-2011, 03:47 PM
