-   -   stone guard or not (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/641004-stone-guard-not.html)
Jrboulder 11-24-2011 08:47 AM
I don't see them as much stone protection. I left them off my car after the repaint. All the chips on my car are lower than the guards would have been.
I will agree with you there. My cab has a lot of chips at the very bottom of the rocker right abouve the black aero effect 951 thingy. My stone guards are also pretty beat up.
hoover 11-24-2011 01:37 PM
Anyone got a link to the sale of these stone guards on rennlist please?
Jrboulder 11-24-2011 03:17 PM
F/S VINYL STONE GUARDS - Rennlist Discussion Forums
hoover 11-25-2011 05:17 AM
Thanks for your reply.
Porsche-O-Phile 11-25-2011 05:54 AM
Originally Posted by dondarnell (Post 6389867)
What kind of film do you use?
I bought several rolls of surplus vinyl stock from a sign shop in Burbank when I worked out that way a few years back - sign makers/printers go through enormous quantities of the stuff and end up with a lot of leftover strips anywhere from an inch or two to maybe 3' in width. They were just selling the raw material off for whatever they could get for it so I picked up the end piece of a 50' roll of black, of clear, of white and a thin strip a couple of inches wide of silver/reflective. Also some red and yellow to make track car graphics. I think the whole shootin' match was about 50 bucks. Check around.
Get a roll of trace paper and carefully make a template of your existing stone guards (or if you happen to have a set of new factory ones in the packaging you can use those). Then get a cutting mat and an exacto knife and cut 'em to shape. Easy, simple. Can be done in an hour at home.
Obviously thicker material is better. Sign shop stuff tends to be a little thin (4-6 mil) so you may want to double them up (I did) to get better protection. I'm sure if you look around you can find thicker stock as well (10+ mil) online or at a supply shop. Might cost a little more. Look around, there are a lot of options out there.
962porsche 11-25-2011 06:20 AM
the mill thickness of the overlays should be 16 mills thick . there should also be 6 overlays in the set !
any thing under a 10 mill thickness will not protect the finish in any way shape or form .
even con-tact paper is thicker than 2 mills at a 3 mill thickness .
in my shop we can remove the old overlays in about a half an hours time . there is a very ez way to do it that
will not harm the finish in any way .
like i stated before you can get the right 16 mill vinyl online for about 50 dollars .
Porsche-O-Phile 11-25-2011 07:26 AM
That sounds about right - the stock guards are pretty thick stuff. Even my "doubled up" guards were thinner than stock but held up pretty well and I didn't get anything that was able to punch through it. Obviously thicker is going to be better (but a bit more expensive, a bit tougher to cut/form, etc.)...
aljolyn 11-25-2011 01:39 PM
I guess I'm the guy from Rennlist with the stone guards. If I can help anyone let me know. You can either use the link Scott left, PM me or email me at mpmastro@yahoo.com. I made a few different styles of the guards in clear, matte or gloss black. Made some other goodies too like front license plates. I guess I'll make a separate post over here.
Jrboulder 11-25-2011 03:07 PM
Scott-- every time you post pics of your 951 it just blows me away.
Thanks!
alan6272 11-25-2011 05:44 PM
I have decided to go naked and leave the stone guards off. Mine were not damaged by road debris but rather from splits and cracks but I like the way it looks with out. True from a distance they are almost invisible but up close I think they make the car look like a redneck off roader:rolleyes:
951 Scott 11-26-2011 06:26 PM
Like these two JR.....there are three cars in photo #1 which you can see the stone guard...http://forums.pelicanparts.com/uploa...1322364393.jpg
http://forums.pelicanparts.com/uploa...1322364402.jpg
Ga 951 11-26-2011 07:15 PM
I have to say, your car outclasses the boxter next door x1000
Although I have to admit, a Cayman gets me droolin'
alan6272 11-26-2011 07:37 PM
I agree with Ga 951 the 944 is much nicer than the boxter
GreenWater 11-27-2011 10:33 AM
Agreed, 944 is much nicer than the boxster, but the cayman is sexy.(Modern 944?)
Porsche-O-Phile 11-27-2011 10:47 AM
The Boxster handles like a dream and is a cabrio to boot. I love em personally but need a 2+2 or 4-seater so the option is a 968 or 911 for a drop top...
The Boxsters have depreciated enough where they're viable for track cars - much like 944s were at about 10-15 years of age.
