A buddy of mine had some sort of compress-the-valve-spring tool that we used on his 944. So if keeper or spring replacement was what we were doing (sorry, I don't recall what we were working on at the time) it is possible.
In any case, you'll know if a valve is bent when you go to pressurize the cylinder and it doesn't hold air...
Old 12-12-2011, 10:01 AM
yes.
Also necessary to get another set of head bolts? Replaced them before and of course the car hasn't started since.
Old 12-12-2011, 06:18 PM
winter-hater club member
nynor's Avatar
i wouldn't bother. that's me. YMMV. what bolts did you use?
"COOL PRIUS!" - Nobody Ever
Old 12-12-2011, 06:23 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
You can use the same bolts and nuts, but take some sand paper and scuff the block side of the washers....make sure you install the washers correctly too. The beveled edge goes up.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 12-12-2011, 06:37 PM
I meant head nuts. Some guys say you have to replace them when you pull the head, which makes little sense to me.
Thanks for the tip on scuffing.
Old 12-12-2011, 07:17 PM
nynor's Avatar
i would probably reuse the nuts, if they were new for this job.
Old 12-12-2011, 07:24 PM
89-944NA's Avatar
Also make sure the washers don't turn when you torque down the head nuts. I put a small drop of paint on the washer/head union, let it dry, then torque the head. If the paint drop breaks you can see that the washer has turned.
Dealer service manual only calls for the replacement of the washers, or scuffing them if you plan to reuse the old ones. Somewhere along the line someone said you needed to replace the head nuts, but that is not true according to the factory service manuals. Aftermarket head studs/nuts may be a different story.
Semper Fi
Old 12-13-2011, 05:55 AM
