Ok, I carrying out on some routine maintence here, first time for me,...
Ok, Im going to replace the cam tensioner on the car, the engine oil, and the spark plugs. Now, for spark plugs I got the bosch 4 tip plugs. The engine oil, I got Mobil1 15w-50.
First, I just removed the park plugs and I noticed that they were all considerably clean. Except that the plugs for cyclinders 3 and four had some oil of them. Now, the oil was on the threads fartherest from the firing tip. Now, the tip of the plug was just black, there was nothing caked on it or damage, no white deposits,... basically according to the haynes manual, they are normal. Now, how would there be oil on just the thread portion of the plug? There wasnt alot of oil either, just alittle. Plugs 1 and 2 had nothing on them. Whats up?
{1987}944S - (SOLD). |
Erm, that's perfectly fine. My plugs are a bit withe, i run a bit lean as it seems... But the oil is probably some lubrication put on to get them out easy and to prevent them stripping the head... By the way, it should be a bit there on 1 and 2. But a bit of oil on the thread is no problem. All seems perfectly fine.
Ok, good,... I didn't think anything of it really,... I mean the tip of the plug is more exposed then the threads so I makes sence. Well, I replaced the cam tensioner and all the plugs,... everything went smooth. The car runs very well,... tomorrow I am going to replace the engine oil,... It is raining here so I dont want to try and attempt to get the car up on the ramps while it wet.
Re: Ok, I carrying out on some routine maintence here, first time for me,...
BTW, what is the group's consensus on the +4s in the 16 valve engines? Thanks. Jim
Jim Griffin JGriff@JGriff.com 1990 944 S2 JGriff.com "Excite the senses, drive a Porsche!!"
I can't comment on the effects of 4 tips on a 16 valve engine.
But.................I think they are a waste of money. Too expensive. And if you notice a dramatic improvement in the way your car idles or responds, I would look at the rest of your system (coil, rotor, distributor cap).................................. All things being equal .........a 4 tip plug is not worth the money....but they do look cool
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Part number? I have the box here and there is like two numbers. the first number says order number and it is 4477 and the second number 0242235627-05P. Hope that helps. Well other than ae1969's comment, i havnt got any others. I dont want to really judge the plugs right now until I get the new oil in the car. From What I have seen so far,... the car seems a tid bit more steady on idle but it could be just as well be a mental thing where I think It sounds better but isnt. To small of a difference to pick up. It starts up nice though. I'm sure it is going to start up real nice when I get the new oil in too. Also, it appeared that throttle responce was a tid bit better too. Anyway, when I get the new juice in her, we'll see.
4477 is the part #,I sell these plugs everyday.
Hey Overkill dont forget your tranny out back,while your doing maint.
Texas hosts the 928 Owner’s Club OCIC in 2009 www.928ocicdfw09.com 1980 928 5 speed and a few mods.......... ![]() 928 OC member PCA member |
I already replaced the tranny fluid a couple of weeks ago. But, Im going to replace it again soon. I want to put mobil1 in the tranny too. I have valvoline synthetic in there now. I want to change it again because everyone recommends mobil1 or swepco, also the old tranny fluid looked really scary so by flushing the the tranny out again I can be sure that all the old stuff is completly out. I just need time!
HOLY CRAP!!! I can't believe! I changed my oil and oil filter and my car,... sounds like a porsche! Geeez, the car is idling ALOT better! Its humming! Also, the plastic barrier thing just after the windshield under the hood use to shake and hit the under portion of the hood and makes this annoying tapping noise. Iwas going to take care of the one day, but its not doing it anymore! The engine is running that much better that its not vibrating as much. Its so smooth! With the new oil/ oil filter and the new 4 tip plugs, the car is so much more stable and VERY peppy! Very good throttle responce! Geeez, I am so impressed!
Overkill - did you do the whole Tensioner (chain, Tensioner, Rails, etc) or just certain parts???
I'm getting new plugs and wires next week - hope mine gets peppy from it!!! Those wires are pretty expensive though!!! 944SBoyeee |
I didnt replace the chain, I replaced the whole tensioner thingy with the plastic rail thingy. I didnt get new wires because I really dont think that they are all that bad right now. Right now, if it is not broken not going to fix it. Im not looking for more performance right now. I just want to go back to school. I want the car in good running shape before I go.
Ok, i noticed somthing,... on the cam cover there are two black circlular cap looking things that are kinda like spitting out a tid bit of oil,... why? Is that bad? I noticed that the one closet to the windshield was doing that before the tensioner change. Why is it doing that?
Ummm, ok now I have a leak! I'm not taking it as a HUGE problem. It is the cam cover. It is leaking down on the exhaust and creating some smoke. I cranked the cam cover bolts to like 18lbs. I think I'll crank them a bit more. You think? I clean the rubber gasket off so there isnt anything lodged between the cover and the gasket. Also about the two circular black cap things on the cam cover,... there is a samll amount coming up through it. Why is it doing that? When the engine is running, is there pressure under the cover?
Overkill:
You did put in a new valve cover gasket when you put everything back together, right? If not, that's probably why you're leaking up top! -Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
I didnt
So I guess I'm going to have to,... also I cant get the bolts any tighter than 15lbs, so what does that tell me? That the threads are stripping? I didnt turn the bolts anymore. What about the black cap things on top of the cover? There is oil coming up and out of that too. Just a little though. Also,... amuse me, how much does a good used head or even a new one cost if they are indeed stripping?
Are you sitting??? I've heard horror stories of $5,000 heads for the S... I'm sure that's new from Porsche. I haven't heard any used head stories.... good luck man.
overkill:
When you took off the cam cover, did it come right off did you have to dis-assemble the front timing pulley mechanism? I don't know if the S is different from the NA in this respect. If not, I too spit a little oil from the gasket you're referencing. I'd like to change it, but didn't think I could without taking apart the belt assembly up front. Just give you some blind faith, engineers usually make the bolts of softer metal than the threaded material (though in this case the threads are in aluminum - #@%^)... Let me know about the timing pulley.
Jake 1983 Euro 944 (Mine) 2000 BMW 323i (Hers) 1997 Sentra (unclaimed!) |
Oh no, i just took the cover off. All I have to do is remove the bolts then kinda work it out from under the fuel hoses.
Hmm, you know what though!?!?! Its like almost everyone of those bolts on that cover is doing that though. Not just 1 or 2 of them but like all of them. How would every single one of those bolts be stripping the holes? I need my new gasket! Argh!
overkill-
A couple of things. The oil on the plugs could be leaking from the head into the top of the plug area. When you removed the cam cover, you probably noticed the seals around the spark plug opening, these can weep over time. The spec on the bolts for the cam cover is only 7-8 ft/lbs, you don't want to strip out the treads in your head. Did you torque them in the proper sequence during re-install?? I ask because when I replaced my chain tensioner, I reused the gasket and had no leaking. The proper order is to start in the middle then diagonally across to the other side then straight up and back across. Working your way outwards in an X pattern. BTW another tip, when you go to install your new gasket, use a little RTV (and I mean just a thin film) on the sections of the gasket that change elevations. This will help it seal those edges better. You can also use this thin film on those spark plug seals. As for spark plugs, I ran the Bosch +4s. They were OK. I recently replaced them with the regular Bosch Copper plugs, don't notice any change in performance plus these were cheap! Good luck with your repairs. Cheers, Riff '90 S2
Riff '90 S2 |
