gjs
glennspiegler's Avatar
How bad is this, valve job?
Was so proud to be replacing fuel line myself. 88 911 220,000 miles. First the fuel line rubber hose ruptured by inj fuel rail. Removed the intake manifold to send orig fuel line to Mr. Hippe in Fla for recond. Pulled the injectors while there for reconditioning. The intake valve #4 which luckily was closed has this puddle of oil in the photo. All others appear dry, but when I opened valve to check the play, there was none, the oil drains out and u see the carbon on the lower valve seat. This wiped away easily, see last picture I think next is to remove exhaust valve cover and check for play. Could this be a bad stem/guide seal. I am not sure how to proceed. What the fate of my daily driver, or used to be. Thanks for such knowledgeable help. Glenn
Both #4 to right, #5 to left
#4
#5 to left of #4
#4
#4 open
After wiping #4 gently
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff
2015 Cayman S
1948 Willy's Overland Jeepster
2013 Chev Sub
2004 Nisson Xterra
Old 12-18-2011, 02:00 PM
ernie9944's Avatar
You are welcome here,but you'll be better of asking for help on the 911 forums they should be peoples over there with answers to your questions.GL
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 12-18-2011, 03:02 PM
9FF 9FF is offline
9FF's Avatar
LoOk GuYs iT hAs No CoOlAnT! No comprehend, tilt, must destroy!
You might have more luck posting in the 911 forums, us water-cooled 4-banger Audi folk get awfully confused by proven and reliable technology
Old 12-18-2011, 03:08 PM
gjs
Thank, my error. Moderator please delete. I will repost. Glenn
2015 Cayman S
2013 Chev Sub
2004 Nisson Xterra
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Porsche Crest
Laffed liked hell.. spilled my Belgian ale..
To OP, GREAT pics man.. Bon Fortune'
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 12-18-2011, 04:42 PM
GreenWater's Avatar
Your problem is easy. Not enough coolant. Make sure the car is topped off with coolant and you should be ready to go.
www.only944.com to get a one of a kind shifter cover for your 944
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 12-18-2011, 07:33 PM
