petrolhead611's Avatar
Send a message via AIM to petrolhead611
87 10.2:1 compression motor into an '86 924S (9.7:1 originally)
Are there going to be any electrical incompatabilities?
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 01-18-2012, 05:19 AM
the guy with the wrench
phlip's Avatar
Not sure about in UK but, '87 engines were not 10.2. Only '88 were.
The engine code has to be M44/09 or M44/10. Or look at the pistons.
Phil
______
I have no more 944's
And I'm not sad about it at all
I only race BMW's now
Old 01-18-2012, 07:35 AM
9FF 9FF is offline
9FF's Avatar
87 in the UK and ROW were all 10.6cr and use the pistons on the right. US were still 9.5cr in 87.
Old 01-18-2012, 07:41 AM
Redline Racer
HondaDustR's Avatar
No, there should be no problems as long as you swap all of the existing wiring and sensors onto the new motor. The 924S uses the late DME system, but the early wiring harness style. Also, the dash gage temp sender is early style, but I believe the holes and the threads are the same and the senders will swap over. It's a win situation, as the 2.5L desperately needs that extra compression, although all 944 motors had 10.6:1 pistons in Europe. Maybe the 924S was a special case and ran the 9.5:1 pistons even in Europe. If you are increasing the compression, ou may need to swap the chip (or the entire DME would do it) out of the 87 DME into the 924S DME for best benefit, but the tuning may be the same between the models anyway. Another plus is the cam in the 87 motor should be the later spec cam with slightly more exhaust duration and overlap for slightly better performance and should also be used in the car.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-18-2012, 11:54 AM
Dawgz83948's Avatar
The extra compression may be good for 10-15hp. The DME programming doesn't even need to change to support that. Electrically (except for the possible lack of O2 sensor) they are identical.
Old 01-18-2012, 12:28 PM
i do a simil change from a 86' 944 USA engine to a 84'944 EURO engine.You can feel the difference in every gear and RPM,s but is not so dramatic....
If you have a good 87' engine is OK and it have the autotensioner for timing belt.
I had differences on the block and "swap" from the engines this parts:
-alternator/AC bracket
-temperature sensor(gauge) not the same hole
-metal water pipe(on the exaust side)
-chack the exaust manifold there are diffferent models in the years,beter is the more linear one
-don't now is 924s have the idle speed control(motor) or bimetal one? so maybe put it from your engine
for the rest is the same,maybe your engines have same brackets but just take care of this,is easy when the engines are out.
I prefer to check clutch(better change it) and do a head gasket job so you are sure that no need to do anythigs in next years....
If you are in doubt about the engine is good to lock main,rod bearings and balance shafts,they are not expensive and you never look oil 0,0 bars on idle in a hot day if you want to keep the car.
porsche 924 carrera gt 90% ready
porsche 944 NA 86' half 951
951 full project for 944
chrysler 300M
6 x 924 and 944 canibalized or death
Old 01-19-2012, 08:27 AM
