Newbie
Engine wobble at idle
Had a pretty significant engine shake at idle rpm and so was inspired to replace plugs, caps, rotor, and cap.
When I got the leads off the cap, one of the towers was all blowed up with material mising. Figured it was not producing an efficient delivery of electrons as it's designed and so not firing on all 4 cylinders efficiently. Post work it's much smoother but not great. Probably have an intake leak or manifold issue..looks rough
An intake leak is pretty easy to check with a smoke test. Will also check the intake manifold and manifold gaskets.
Good luck, George Beuselinck |
Does it smooth out at a 1300 to 1500 RPM? If so, how old are the motor mounts?
Dan 86 Guards Red 951 (the best so far) 86 Black 951 (sold 12/31/09 PITA) 86 Guards Red 951 (sold in 7/15/00 (first love) 90 Plymouth Voyager, 2.5 Turbo 5 speed |
Newbie
yeah, smooths out great once you start rolling, this shake is just at idle.
85 Mercedes 300cd sold 98 323is sold 02 325i sold 86 944 |
sounds like motor mounts to me. Very common.
