-   -   DME TEMP SENSOR (Needed) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/658369-dme-temp-sensor-needed.html)
Dean924s 02-15-2012 11:28 AM
I need one for my MS project. The sensor that the blue plug on the harness plugs in to.
Here is a photo for reference.
http://www.clarks-garage.com/graphic...-locations.jpg
Anyone have a working one lying around that they want to get rid of?
post up here or email me direct at dsmith@radio.fm
Thanks!!!!!
Dawgz83948 02-15-2012 01:29 PM
They're available at ALL parts stores.
ernie9944 02-15-2012 03:30 PM
For your car here on Pelican "BOSCH" part#944-606-125-00-M14 =$20.75:cool:
seafeye 02-16-2012 07:24 AM
How do you test it to see if it's good?
porsche8777 02-16-2012 12:37 PM
Take an ohm meter and check it across the terminals. Cold should read about 3.4 kohms. Put tip in boiling water it shoul read about 200 ohms.
Dean924s 02-16-2012 05:23 PM
I was hoping to get one on the cheep. It will be for a one time use as I am running the final testing on the bending with a composer harnes.
seafeye 02-16-2012 06:00 PM
Huh?
ernie9944 02-16-2012 06:38 PM
Pelican will also supply you with a cheap one "brand FAE" #944-606-125-00-M323 cost $8.00.:)
