What is this part called?
I got a little excited when taking the speedometer out today and broke this.
It goes from the rear of the speedometer to the rear of the tach where it plugs in.
If it helps, I have an 83 with a manuel trans. If anyone has one, I'll be needing one! Thanks
Old 02-22-2012, 05:22 PM
FrenchToast's Avatar
That is the magic mystery odometer fluid pump relay servo line cooling jacket assembly.
I have no clue, sorry. Is there a shift light in the speedometer? Not sure why the speedo would need to communicate with the tach electronically.....
Just wanted to post because I was wondering where in CT you are?
Good luck!
Old 02-22-2012, 05:37 PM
Thank you Jrboulder!
FrenchToast, Im in Bethany.
Old 02-22-2012, 05:44 PM
Originally Posted by Jrboulder View Post
Hall sensor 944-641-251-00
Isn't that what I said?
Have a good evening!
Old 02-22-2012, 06:09 PM
