Engine running problem
I was driving my 85 NA 944 at speed (70mph+) when the engine started to run extremely rough. This persisted for a few miles.
I finally pulled over, turned off the ignition for a few minutes.
It started, ran very rough and rpms speeded up and down wildly for a few minutes.
Then, within a couple of minutes, it ran more and more smoothly until it ran normally.
Since then, it has run perfectly normally as if nothing has happened.
What can this be? Clogged injectors that suddenly unclogged? Blockage in the fuel line? Timing belt? (I can't imagine that). Airlock in the fuel line? Temporary scramble in the computer chip?
Old 04-18-2002, 04:51 PM
geoffbaltz's Avatar
I would think bad gas or your clogged/dirty injector hypothesis.
Geoff Baltz - St. Louis Region PCA
Board Member/DE Chairman
PCA HPDE Instructor
Old 04-18-2002, 04:53 PM
xero's Avatar
if you were low on gas you could have got some air in your fuel line? usually happens on corners
Old 04-19-2002, 04:13 AM
