-   -   failed smog please help (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/661181-failed-smog-please-help.html)
mlang88 02-26-2012 07:50 PM
hey guys failed California smog. the cars has new plugs, o2 sensor, vacuum lines the cats about 4 years old. any help would be appreciated here are the numbers.
1988 944
15mph
%co2- 12.7
%o2- 2.3
hc max-83 gp-293 meas- 180
co max-.75 gp-2.25 meas-.60
no max-575 gp-2002 meas-2822
25 mph
%co2-13.0
%02-1.9
hc max-65 gp243 meas-58
co max-.63 gp-2.13 meas-.60
no max-738 gp-1802 meas-1410
Im thinking the AFM is way out of adj.
Matt
Techno Duck 02-26-2012 07:59 PM
High NOx is usually a result of the car running excessively lean. The most common reason for this are vacuum leaks. Second is just a bad cat. Make sure you get the cat very hot before taking the test, drive the car on the highway for a little while and see if you can 'roll right in' off the street for the test.. dont shut the car off or let it cool off.
mlang88 02-26-2012 08:47 PM
Yeah that was after a hour on the fwy and a five min wait for the paperwork then test
Cocacolakidd 02-27-2012 02:36 AM
Could also be the O2 sensor making it run lean
Could be also the DME temp sensor on the block is defective.
Test both...
mlang88 02-28-2012 06:40 PM
okay i tested the DME temp sensor and it seems out of spec here are the numbers
@55-57 deg 2.90 k-ohms spec is 3.3
@176 deg 264 ohms spec is 280-360
so lower than specs means leaner but would it be that much of a difference?
Cocacolakidd 02-28-2012 09:46 PM
The DME temp sensor is not that much money - replace it. It has probably been bad for quite some time now. If you run a 944 motor for to long with to lean of fuel supply you take a good chance of burning the valves.
Dawgz83948 02-29-2012 07:47 AM
The fan of CAPS LOCK has passed his smog. He cheated but he passed.
