failed smog please help
hey guys failed California smog. the cars has new plugs, o2 sensor, vacuum lines the cats about 4 years old. any help would be appreciated here are the numbers.
1988 944
15mph
%co2- 12.7
%o2- 2.3
hc max-83 gp-293 meas- 180
co max-.75 gp-2.25 meas-.60
no max-575 gp-2002 meas-2822
25 mph
%co2-13.0
%02-1.9
hc max-65 gp243 meas-58
co max-.63 gp-2.13 meas-.60
no max-738 gp-1802 meas-1410
Im thinking the AFM is way out of adj.
Matt
1988 944 with early motor
1974 Bronco,
1965 BSA Lightning
Old 02-26-2012, 07:50 PM
That Guy
Techno Duck's Avatar
High NOx is usually a result of the car running excessively lean. The most common reason for this are vacuum leaks. Second is just a bad cat. Make sure you get the cat very hot before taking the test, drive the car on the highway for a little while and see if you can 'roll right in' off the street for the test.. dont shut the car off or let it cool off.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-26-2012, 07:59 PM
Yeah that was after a hour on the fwy and a five min wait for the paperwork then test
1974 Bronco,
1965 BSA Lightning
Old 02-26-2012, 08:47 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Could also be the O2 sensor making it run lean
Could be also the DME temp sensor on the block is defective.
Test both...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-27-2012, 02:36 AM
okay i tested the DME temp sensor and it seems out of spec here are the numbers
@55-57 deg 2.90 k-ohms spec is 3.3
@176 deg 264 ohms spec is 280-360
so lower than specs means leaner but would it be that much of a difference?
1974 Bronco,
1965 BSA Lightning
Old 02-28-2012, 06:40 PM
Garage Helper
The DME temp sensor is not that much money - replace it. It has probably been bad for quite some time now. If you run a 944 motor for to long with to lean of fuel supply you take a good chance of burning the valves.
Old 02-28-2012, 09:46 PM
Dawgz83948's Avatar
The fan of CAPS LOCK has passed his smog. He cheated but he passed.
Old 02-29-2012, 07:47 AM
