-   -   Mixing Tolerance Groups (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/662502-mixing-tolerance-groups.html)
darud35 03-02-2012 04:10 PM
Hey all,
I'm rebuilding my turbo engine. It's a tolerance group 1 set of pistons/block. The block is pretty scored. My question, is it a bad idea to go with, say a group 2 block? Obviously a group 0 will not work woth the larger pistons. I thought I'd heard you can increase block tolerance vs pistons.
Rasta Monsta 03-02-2012 09:03 PM
Piston coatings can make up for clearance lost to honing. I recommend a machinist with experience with nikasil/alusil bores.
