Replacing starter on '87 944 NA
Any advice on getting the starter off? The bolts will not budge and the old starter was only 2 yrs old so it has been replaced recently.
Old 07-08-2015, 11:42 AM
Very long breaker bar, I'd say.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 07-08-2015, 11:51 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
"Wake" the bolts up with a hammer to the heads of the bolts and then a breaker bar.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-08-2015, 01:18 PM
Thanks guys!
Old 07-08-2015, 01:19 PM
A good wrench got it off. Check out the pix. Has anyone seen this happen to a starter?
Old 07-08-2015, 02:32 PM
Snapped the end right off. It's a Bosch SR39X 779 30127.
Old 07-08-2015, 02:37 PM
Proprietoristicly Refined
John_AZ's Avatar
Practice:
VWVortex.com - DIY Starter Upgrade/Repair/troubleshooting/Replacement (manual tranny)
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-08-2015, 03:07 PM
More Boost!
Porsche crank strong like bull!!! Never seen a starter snap like that.
Old 07-08-2015, 05:37 PM
Porsche Power
Did it crack when you tried to get it off, or do you think it was already cracked? I would think there needed to be some type of interference to crack that off. Either the starter was installed incorrectly and the housing hit the flywheel, or it got stuck during removal and broke when using the breaker bar.
Old 07-20-2015, 10:20 AM
16vCorey's Avatar
I've never seen it happen on a 944, but I have seen it happen plenty of times on other vehicles. It usually happens when there's another problem, and it backfires while it's cranking.
Parting '84 944 with 103k. Pics here: http://smg.beta.photobucket.com/user/cheezus/library/944?fromLegacy=true
Old 07-24-2015, 08:13 AM
Bradical's Avatar
Ooooo, if you are missing the aluminum interference sheild for the reference sensor, which I believe started in 1987 when the starter was updated, it can cause misfire during cranking and do this!
ALSO- you will need to purchase the updated sensor bracket as well unless the sheil is just missing (unlikely). I also recommend purchasing two new sensors just incase they break while you are doing this, and also so you can use one to make the imfamous ring gear spacing tool for setting the new bracket.
Explains your need for yet another starter!
PCA - Florida Citrus Region
Old 07-24-2015, 11:12 AM
