wilkrod's Avatar
Aftermarket ignition trigger
Hi all,
Wondering if anyone has ever tried using an aftermarket, i.e, Crane, Pertronix, etc. Ignition trigger installed in the distributor?
I use a VR sensor in the distributor of my Lotus to triger the ignition events via MegaSquirt, and was going to look at doing the same for my restoration project 87 944S.
Thanks much
Jeff
Old 03-05-2012, 08:40 AM
Ing trigger
Did you ever get any answers? I am going down this path as well. Joel
Old 01-14-2015, 05:42 PM
plays with toy cars
sausagehacker's Avatar
Talk to user Dougs951s over on Rennlist, he recently installed a Megasquirt setup on his 951. He used a missing tooth trigger wheel on the crank pulley and a Ford VR pickup. The crank appears to be the best place for it, the trigger wheel is $40 from:
Trigger-wheels
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 01-14-2015, 06:14 PM
Thanks, I have been away a while. Are you going to COTA in Sept for the 6 hr race? J
Old 07-23-2015, 09:15 PM
txhokie4life's Avatar
There is a also a local racer that uses one -- connects the pickup to either the sway bar or steering rack and picks up the missing tooth off the crank. I believe he runs wasted spark.
M
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 07-24-2015, 11:15 AM
