Tach no worky at idle
Pulled the instrument cluster a couple of weeks ago to replace the light bulbs and odometer gear , while taking the cluster out I broke one of the clips on the lower, right connector, anyway the Tachometer has always worked fine but now it won't read the rpm while at idle , could it be related to the broken clip on the connector? can the clip be replaced?
What else can it be?
Thanks for your all your help
Leonel
Old 03-14-2012, 09:37 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
I have found that those clips break easy and can easily be replaced - There may not be the correct contact for the Tach. to work properly with the pressure clip broken - The Tach. is controlled by that connector - Spread the upper and lower flanges of the connector to remove the old pressure arm buttons, and do same for replace.
Place a wanted add with what you need - I have done this exact same and received good replies, and replaced just the broken lever/clip.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 03-14-2012, 10:24 AM
Thanks Cocakidd , I'll do that
Old 03-14-2012, 02:13 PM
