87 944S Almost Chockes when slowing down to a stop
I have a 87 944 S that has a little issue. I just got it running after a rebuild, and after the ICU and Computer died after a stuck starter motor.
The car idles fine (could be tuned slightly smoother) and drives fine, except when I slow down to an almost or compete stop. The car almost chokes (and sometimes do), the tac drops down to the bottom and the car looses all power. It happens when I slow down fast from driving speed, like when I slow down to go into a parking lot, slow down to a red light or when traffic is backed up. Anyone know what the issue could be here? I'm thinking something with the throttle but I'm no expert. thanks
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
Porsche 944S Club Sport
mhariush;
My car use to do the same thing...Could be a few things... check your fuel pressure should be ~50psi. Check vacuum with a gauge...then replace O2 Sensor.. also spark plug gap affects timing... Keep me posted...Later
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
