944 rotary conversion
Hi, im looking into getting a 944 soon and wondering if anybody has done a rotary conversion? I was thinking of swapping in a 3 rotor and was looking for some details on how invlolved it actually gets/if its doable. Thanks
1976 Porsche 911s-Balanced and blueprinted 2.7, Rennsport bilstiens, 21/27 hollow tbars, rennline strut brace/strut monoballs, poly front bushings, neatrix rear bushings, Hawk pads, SSI's, M&K 2 in 1 out, 15x7 fuchs wrapped with yoko s-drives, turbo tie rods, steering rack raiser, and JL stereo. Avid national kart competitor at the sharp end of the field-sponsors welcome |
A gentleman from down under built a 924 rally car with a rotary. It required major modifications to the crossmember to fit it among others. He's over on the 924board.org.
Personally, I'd not bother, just buy Mazda's copy of the 924/944 and get a 2nd-gen RX. The Rotary is a bit of a torqueless wonder (though they do sound good with a PP) and if the 2.5 is in good shape, run it until it dies. If you want more power, put a V8 in it. 924Board.org :: View topic - Project RX924 begins!
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
down around Oklahoma City there is a guy with a 924Rotory, but I havent seen him in a while.
pointless. the 944 has no guts as it is - no need to put something with an even worse torque curve in it.
they sound cool and go like hell, above 5000rpm... |
944's have no guts? Are you kidding me?
Jonah Boyd 78 928 5 speed - #111 81 928 5 speed - the "Copper Turd" 81 928 Auto |
He is not exactly kidding you,the 2.5 ltr 8v NA could have a little more HP & torque & it's a known fact.And I personally believe that the best way to achieve such a gain is going with something more natural to the 944,a 968 3.0 ltr 16v NA not a V8 or Rotary.Been done successfully to a number of 924S/944 NA & S2 without major problems.Don't forget that the torque plot for a 968 stock 3.0 ltr is very nearly flat from 1000 RPM to 6,500 RPM & it peak at 225 pound feet at 4,100 RPM.In fact as low as 1000 RPM the 968 motor produce 147 pds/feet of torque versus 117 for the 951 & it's not only HP that make a car fast from point A to B but also how the torque is deliver.
---924S ---snake1996/ 83-944 ---S2 to S3
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
That said, making a 968 vario-cam engine make that hp/tq is a easier and cheaper. As for the rotary, I don't know much about them, other than that reliability isn't their strong point. And some rotary trivia: NSU (better known now as Audi) is the first manufacturer to put them in a production car, not Mazda. The NSU Ro80. |
If I am to consider rotary....it has to be turbocharged as in the 3rd gen RX-7. Only then the torque and HP gain will be considerably better than the 2.5L. It will be even better than the 968 3.0L
Dimi Paralanov Flying Horse Motorsport flyinghorsemotorsport@gmail.com |
The obvious rotary motor to use,if you must, is the Renesis out of the RX8
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
What kind of details? a whole bunch of $1000 bills, or a whole bunch more of $100 bills, Many thousands of $1 bills. Even more coins...
Compression, displacement, more VE. Easy peasy lemon squeazzy.
1986 944 Gemballa custom cab 1986 944 shaved lights/bumpers Way too many Datsun Z cars |
dkbautosports.com
i have a **** load of 944's and a 968 6 speed coupe . two of the 944's i did v8 swaps into . one is a 350 SBC and the other is a LS7 motor . the LS7 swap required building a tube car at much cost .
the 350 LS1 swap was cheap to do and kind of ez . with a total spend of 5k . the 350 motor dinoed at 428 HP with tork at 387 . with a GVW of the car at just over 2200 lbs dry weight . i built 99% of what i needed to do the swaps but you can buy kits . my fealing is if you need to rebuild your 8V motor junk it and swap in a V8 . it's cheaper to do that than rebuild a 944 motor . the 8v motors are very low on hp and tork and scaling out the two motors fully dressed . the V8 sbc motor is only 48 lbs more then the over weight 2.5 8V motor . swap in a V8 thats what the 944 should have come with from porsche not the junk 2.5 motor . |
As for true dyno figures, I aint gots. Pretty sure the engine is mentioned briefly in the dark, unlit, un-frequented caverns of an RL post. I'll have to see if I can find it. If anyone REALLY wants details send a PM. But yes, takes alot, including MoTeC and race gas, custom intake, exhaust yadda yadda yadda. Nothing 'bolt-on'. It requires a ground-up build. Any '87+ rollers? ![]() Back to discussing rotary engines. Should really make a new topic for the standard Porsche engine. Last edited by FrenchToast; 03-30-2012 at 02:15 PM.. |
