88 944 heater rod
Hello all.
1988 944 Base. Plastic clip on longer heater door rod broken. I started car, moved the temperature control on dash. I was hoping to see rod move, even though clip was not attached. Rod did not move at all. Once I replace clip, what should my next step be?? Thank you. |
If I'm not mistaken, A/C controls in your year are governed by either vacuum or electrical motors, unlike the yearly models - with cables.
I fixed it. Got new clip. Pushed rod up and popped it in the new clip. Added metal retainer.
Started car and rod stayed up, allowing cool air inside. All good now. |
In the Fires of Hell.....
That is one of the cheapest fixes for our cars you will find - be happy
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Which one is which? I get confused about the two of them. Which clip I mean…
Shane - 1984 928S |
Where did you source the clip, from our host?
Lucky owner of a couple of 911’s and a 924 |
Actually, I sourced from 944online. I get most everything from Pelican though. I will almost guarantee the Pelican has this item.
The rod closer to the firewall is defroster. The the rod further back toward the console is the flap to control heat. I pushed the rod up, and attached rod in new attachment clip. Slid metal retainer over plastic clip. |
Good write up here: https://944foot2thefloor.blogspot.com/2009/09/how-to-repair-heater-control-valve-on.html?m=1 Also, if you find the plastic lever on the heater valve is broken, it is likely that someone pushed the hot lever all the way over to the right. You should push it only until resistance is met.
Early '85 |
