-   -   Alarm system going off random.. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/669507-alarm-system-going-off-random.html)
matty89 04-03-2012 11:24 AM
i just took my car out of storage and now my alarm systems (OEM ) is going off random.... no one is around it and it goes off.... any ideas ? porsche 944 1986....
matty89 04-03-2012 02:37 PM
its goes offf once a day and im not home to see it lol
John_AZ 04-03-2012 03:25 PM
Hi Matty,
You posted the alarm goes off randomly.
Sometimes disconnecting the battery--waiting a few minutes and reconnecting may reset the alarm.
I do not know if this will help. This will not fix the alarm only bypass it.
You have the '86 944 so read the note on bypassing the alarm at the bottom of the page--check which relay you have. There are 3 styles.
Bypassing factory alarm
944 Online Forum - The Porsche 944 Forum For The 944 Enthusiast.
This may be a last resort solution. Try at your own risk.
It sounds like a wire, ground, coil connection is shorting.
Sorry, not much help.
John
matty89 04-03-2012 04:23 PM
Originally Posted by John_AZ (Post 6665242)
Hi Matty,
John
thnx john i will try this week end lol :P
John_AZ 04-04-2012 05:03 AM
matty,
Clarks garage also has the bypass info with pictures:
Alarm System - Bypassing
A cracked ignition switch could also be the problem (?).
GL
John
RedBaron 04-04-2012 11:57 AM
The horn is located behind the battery for the alarm. I had the same problem and I just removed the horn. Now the lights flicker occasionally but it is more of a temporary solution. I will look into the ignition coil as well. I recall reading that a bad battery can cause the alarm to go off, although I have no idea why that could cause a problem. If you find a fix, please let us know!
bxfe 02-22-2013 09:14 PM
94 968 alarm going off at ramdom
My daily driver 968 's alarm just randomly started going off whenever the car is locked. Ideas on the cause?
Gary
gordonmacwillia 06-26-2014 05:05 AM
I have the same problem with my '87 944S. I replaced the brain, but no joy.
flash968 06-26-2014 05:20 AM
it's frequently a pin switch, like at one of the doors, the hood, the glove box, etc
jwmc1 06-26-2014 05:21 AM
Check and make sure there isn't any moisture in the fuses / relay compartment. My son had that problem once after washing his car...don't ask...he isn't a car guy.:rolleyes:
targa florio 05-22-2023 06:52 AM
I know this is an ancient thread. Thank you all for the guidance
Just went through this on 93 968 and mine was the hood switch. It was intermittently working and misaligned, just worn out. Unplugged it and immediately got single blink condition
targa florio 04-14-2025 07:36 AM
follow up. alarm started going off again and this time i traced it to frayed / broken wiring in the harness that runs from the engine bay into the hood...seems over time the bending of the wires from opening / closing the hood caused the wire for the hood sensor to break and go open. intermittently
