Remove cluster without removing steering wheel?
Does anyone know of a "trick" way of removing the instrument cluster without removing the steering wheel on a late car with the airbag wheel? I would like to replace the instrument bulbs, but I do not want to risk creating any problems with the airbag system......like it deploying! I have heard rumors that it can be removed without messing with the wheel.
1988 944 Turbo Guards Red - Black Leather Autothority Stage 2 Chip Set Weltmeister Strut Tower Brace 1984 944 - Sold to rcecale |
In the Fires of Hell.....
Not on airbag cars. But it's really not that hard to do.
Disconnect the battery and let the car sit for a couple of minutes and you won't have any problems with the airbags. Just remember to have the airbag plugged in before you turn on the ignition, or you will have to go through the airbag light reset procedure. Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
That Guy
Just take the wheel off, disconnect battery (i like to let it sit for an hour), two torx screws on the back (T25 i think) to pull the airbag off, i think two phillips heads holding the clock spring on and the one big 24mm (15/16 works also) nut in the center. Mark the orientation of the wheel on the splined shaft before removal.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Yes you can do it. Unscrew the surround for the cluster. when taking it out, start at the vents, then the center squeeze slightly the top & bottom toward each other slightly and slide to the right.
Yup. I've done it before. You have to be careful and take your time, but I'm sure its faster than taking the wheel off.
Registered knucklehead
Gregg S.
1983 911 SC Cabriolet, 1989 944 S2 1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455 2000 BMW 528i Touring, 2005 GMC Sierra |
Sure can, at least I did it on my 968.
