balky 944
My 1985 944 starts and runs fine until the cooling fan engages and then it just bogs down and runs real rough. The battery and the alternator have been replaced recently. Any help or suggestins would be appreciated.
Old 04-14-2012, 01:06 PM
Dave Colangelo's Avatar
are you running the stock ECU/chip or has the car been chipped, it could be a fuel map issue if it has been chipped.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 04-14-2012, 01:20 PM
1983 944 N/A
POPS 83 944's Avatar
Check the ground and clean
Old 04-14-2012, 01:21 PM
i'm not positive, but i think there is a switch that kicks the rpm's up when there is additional electrical load.
1988 944 turbo
Old 04-14-2012, 01:39 PM
porscha
matty89's Avatar
whats ur normal Rpm when hot at ? and if u put the A/c on How much does it drop ?
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 04-14-2012, 03:08 PM
my normal rpm when hot is about 11-1200 rpm. I still have the original chip, nothing has been modified that way. I will check all of the grounds again but they looked okay when I checked it but I will double check that I didn't miss anything. I have read that it could possibly be the idle speed valve going bad but that was just a guess on my part and I really don't want to just start throwing parts at it and hope that something works.
Old 04-14-2012, 11:11 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Does the A/C work? Does the problem go away when the A/C is switched off? Are you sure that the A/C compressor actually goes off and on? My thinking here that the compressor may be near seizing and putting an enormous load on the engine. The fans will come on as the compressor comes on.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 04-15-2012, 10:05 AM
the ac works fine. Only the one fan comes on when I have the problem.The ac is not starting at all. It is just the one fan that starts and the engine bogs down.
Old 04-15-2012, 11:00 AM
Update:::I went and checked all of the grond points and cleaned everything real good and tried again. Same result. Well at this point I was really at a loss for what to try next. As a last resort I pulled the battery out of my other car and put it in the porsche and tried that and lo and behold:roblem solved. the battery that was in the porsche is only 6 months old and should be good. I took it to an Advance Auto and had them check the battery and find out that there is a dead cell and any strain on the battery was just draining it to low to keep up with the demand. lesson learned-- don't believe everything that is new is without flaws. Anyway, Thank you to everyone that offered help. It was really appreciated
Old 04-15-2012, 02:27 PM
ernie9944's Avatar
[QUOTE=porsche newbie;6688627]my normal rpm when hot is about 11-1200 rpm.
If everything in tip top shape engine wise the engine RPM should be between 9k & 1000k RPM at normal temp in either early & late 944. 11/12K RPM is a little higth. ex -83-944
- 93-968
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 04-15-2012, 04:40 PM
