AFM #725
Gawernator's Avatar
Red face Wtf? Nose panel removal
Pardon my language, but I guess it's never as simple as you think. I finally got the hood crest gasket perfectly seated around the crest after much heat gunning and with a helping hand. I follow the clark's garage procedure, put up the headlamps, remove the fuse, remove the four body screws from the top of the panel. I go to loosen the two bolts on each side and find this:
I do have a late model car, but I also realize my early model had these rubber flaps, I guess they are to keep out water or something. Clark's 944 doesn't have these, and the procedure doesn't account for what to do. I can barely access the one bolt on each side, and the other bolt and the machine screw are basically inaccessible. Am I supposed to just rip this stuff out? It seems like it's useful, but I don't see what I'm supposed to be doing. Attempting to replace the old and cracked hood crest. Even got my 8 and 10 mm sockets at the ready!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 07-20-2012, 11:36 PM
Andrew Gawers' Dad
CHICKS's Avatar
It's just shoved in there. Grab one end and pull it out. I promise you it will be harder to put in back in. And BTW, you can still buy those new from the dealer, and they're pretty cheap just in case you rip em'.
Old 07-20-2012, 11:43 PM
AFM #725
Gawernator's Avatar
Thanks again man, will try.
Old 07-20-2012, 11:50 PM
On my car, I just slid them back towards the center of the car. That got them out for me. And when I was re-assembling, I forgot to put them back on! How convenient
86 944 N/A (red)
Old 07-21-2012, 07:18 AM
One apex at a time
Dean924s's Avatar
I think I looked those up and was shocked at the replacement cost. I was going to toss a set but held on to them due to the replacement cost. I can not find them in the pelican catalog at the moment
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 07-21-2012, 07:47 AM
AFM #725
Gawernator's Avatar
I pulled mine out without ripping them. Idk if I can get them back in as easily lol. Thank you Porsche for the engineering marvel >
Old 07-21-2012, 12:41 PM
They aren't that bad to get back in IIRC... I think you can kind of squeeze the bulbous side flat and just slide it right in...
But its been a few years since I put mine in... Clean that paint off while you have them out....
Old 07-21-2012, 01:14 PM
AFM #725
Gawernator's Avatar
Will do
Old 07-21-2012, 01:21 PM
Spray it with some silicone lubricant and it should slide right in
86 951 blk
Old 07-21-2012, 03:01 PM
AFM #725
Gawernator's Avatar
That's the least of my worries right now. Still could only get the panel halfway out its stuck on so hard. Got the new crest on but I ended just prying the old one off because it only had the grommets, so this was all for not. And the sides of the panel are rubbing and taking off the new paint, and I can't get it back in...
Old 07-21-2012, 03:28 PM
That Guy
Techno Duck's Avatar
Drop the rubber trim in a bucket of soapy water, it will slide right back in easily.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-21-2012, 04:03 PM
AFM #725
Gawernator's Avatar
This is a nightmare...can't get the panel all the way off or get it back on and it's messing up the paint.
Old 07-21-2012, 05:10 PM
AFM #725
Gawernator's Avatar
... With a friend managed to pry and bend it back in. Paint is scraped off though on the edges :/
Old 07-21-2012, 06:22 PM
