James Chimney
Swapping seat backs?
can you swap the seat backs on a 85.5 944? the drivers side bolster is worn and if I could I would like to swap it with the passenger side till I recover or replace.
thanks.Swapping seat backs?
Old 04-30-2012, 01:57 AM
The seat backs are the same left and right.
Old 04-30-2012, 05:42 AM
James Chimney
how hard, do they have to come out?
Old 04-30-2012, 12:33 PM
I've only done it out of the car. its like 6 6mm allen head screws for each seat and an electrical connector for the drivers side.
Old 04-30-2012, 01:19 PM
Proprietoristicly Refined
John_AZ's Avatar
How does the seat back release work on the inside?
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-30-2012, 02:10 PM
John
The late seats have a realese on both sides. It's pretty handy.
Old 04-30-2012, 02:38 PM
John_AZ's Avatar
ahhh, and the 924S has the early style.
John
Old 04-30-2012, 04:27 PM
Custom User Title
mikepellegrini's Avatar
It's almost do-able in the car. Maybe. The problems would be on the inside next to the torque tube tunnel.
You have two Phillips head screws to take off the plastic covers on each side, then two (I think) 13mm bolts per side. The seat back release has a circlip you pop off (on both sides), then that comes off the shaft. Then the seat back just pulls out.
I just exhanged the seat backs on both my cars for the same reason as you. I did it outside the car because I was installing them at the same time, but if I had it to do all over, I'd try exchanging them while in the car.
It's always been a royal PITA for me every time I've tried to switch seats in a 944. Taking them out is a 5 minute operation, but for some reason, getting them back in is always problematic.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 04-30-2012, 05:22 PM
