Tallest wheel setup for mpg.
I'm looking at doing the v8 swap into a 87 944 but I'm trying to figure if I can get a good cruising rpm. So what is the tallest rear tire I could run? I'm currently running 255/17/40, Could I move to 55's?
Old 05-16-2012, 03:12 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Remember that when you increase the diameter beyond stock (OEM) wheel/tires, you'll have innacurate speedo readings. Bigger tires, faster car for an indicated speedo reading.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-16-2012, 03:34 PM
flash968's Avatar
you would be far better off swapping out the trans
Old 05-16-2012, 04:35 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Your 255/40-17's still match the overall diameter of the original tire - of which the system is balanced to. If you move to a different size tire like 255/55-17's the whole system will be off, including the speedometer rate, over-steer and others. The next question is will it fit under the wheel wells without rubbing - maybe no. Stick with known good sizes...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 05-16-2012, 04:55 PM
meister member
speedracing944's Avatar
A turbo transaxle with the N/A 5th gear swap will give you a 2000 RPM @60 MPH.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 05-16-2012, 05:10 PM
Is there any final gears longer than the 5th in a 944 n/a?
Old 05-17-2012, 11:20 AM
Catamax944's Avatar
Yes ,the 0.68 5th from a '80-'82 audi 5000 diesel .If anyone can source these for a resonable price i'm also interested.
5th gear options, Audi?
Catalin
'86 DD
Old 05-17-2012, 01:17 PM
Eric
You would be better off buying a Honda as a daily drive if you are worried about fuel bills....
Eric
Old 05-17-2012, 02:31 PM
Catamax944's Avatar
255 i think are a bit skinny for a v8 powered 944 . As for dropping your rpm for highway cruising i would go for both soultions to get the best result,taller tyres and tall 5th (either 944na or audi) .And for the speedo side effect from tall tyres get a gps one from speedhut , ideola put one in his 924,should be just as easy to fit in a 944.
Catalin
'86 DD
Old 05-17-2012, 02:59 PM
