AFM #725
Long starting time
So, I just purchased quite recently a 1986 Porsche 944 N/A. The car has great records and the engine was just rebuilt, every single seal, gasket and belt is new. New rollers, tensioners, water pump, thermostat, engine mounts, fuel filter, oil filter, air filter, hood and hatch struts (irrelevant), fuel pump, clutch, heater hose, distributor rotor and the list goes on. However sometimes when starting the car it will take two to three seconds to ignite instead of the usual 1/2 second or less. This is more common when the engine is cold. If the engine is warm, then turned off, then turned back on, then it will start up right away. What is most likely to cause this? Timing issue, dirty injectors, spark plug issue? Thanks
127,000 miles
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Ok,you have new rotor what about the cap and plug leads,you shouldn't have a timing issue,and forget the injectors,go for new Bosch plugs and report back,cheers
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
AFM #725
Bosch Platinum 4's good? Pelican sells them and I have a set of four.
Professional Bull5hiter
There's a non return valve just after the fuel pump. It's supposed to keep fuel pressure at the injectors. I'll bet my left nut it's letting the fuel pressure drop after sitting for a while. Not an expensive part to replace.
Cheers
Jeff 83 944 Guards Red 23 718 GT Silver |
Proprietoristicly Refined
Cheap, single tip copper are the best for the Motronic DME. The best conductivity and performance. This has been discussed for years... BOSCH platinum 4, good/Bad - Rennlist Discussion Forums The 2 to 3 second delay could be a fuel pressure problem. Outback Porsche mentions the antidrain back valve attached to the fuel pump. You could replace the part or get a set of new copper crush washers, remove the part and just clean the steel ball inside. There may be a fuel varnish deposit causing the problem. I would check the injectors and get them replaced ($$$) or send them to Witchhunter WitchHunter Performance - Injector Cleaning & Flow Testing Services to clean, test and reseal--about $100. You may have a leaky injector or an injector with a bad spray pattern. If the FPR & FPD are OEM, you should replace. Does your starter "explode" when you turn the key or does it go wheeerrrr--wheerrr befoe it catches? Could also be the cause. Have you ever changed the fuel filter screen in the fuel tank? and on and on and on.... GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
yarfk
Fuel pressure test information.
http://www.clarks-garage.com/pdf-manual/fuel-01.pdf
------Keith------kfray------yarfk------- 87 944 NA stock 116k 06 Honda Ridgeline 83k 10 Vibe 2.4 AWD (Wife's) Retired My week consist of Saturdays and Sundays
AFM #725
Okay, thanks for the help! I guess I'll get to work...
Garage Helper
While you are in there check also the battery - Our 944's love plenty of voltage power, and sometimes if the voltage/power is a little off with an old or week battery the car will be sluggish to start often.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
AFM #725
Roger that
I agree it could be that your fuel pressure is leaking off (I wouldn't bet my left nut on though like Outback). I would try putting a pressure gauge on the end of the fuel rail to check it. I had to make an adapter to get the thread right for my fuel pressure gauge.
Red 83 944 |
Agree it's a bit of a risk, but it doesn't get much use these days
![]() It could also be a weeping hose/joint that's causing the pressure to drop - You mention you get the smell of fuel inside the cabin on another thread. Check the condition of your fuel lines near the engine bay?
AFM #725
Okay I will check that. I am pretty sure every hose is new, but I'll have to double-check. I am under the impression right now that smell is leaking exhaust coming in through the absent shift boot
