83 944 SPAX Suspen. - Tires rub
I have a 83 944 with the SPAX suspension kit. When I installed it a year ago, I had no problems with tires rubbing. However, my tires where 205 55 15 I believe. I remember they where smaller than the rears. However, on the gas cap the recommended tire size is 215 60 15. I have those size tires and it rubs like crazy when I have full lock or take a sharp turn at speed. It rubs on the inside of the wheel well, against the firewall. I have been driving a few days with these tires and it rubbed so crazy it went to bare metal. Any one have these problems? Should I go back to a smaller tire?
ALSO! The kit says it lowers the front by 30mm but the front is MUCH lower than before. I want to know if others have had similar results. Thanks! |
Bump
Are you from the UK ? I don't think spax is available in US .
You should try the Uk forums: 944 The Independent Porsche Enthusiasts Club • View forum - 924, 944, 968
Catalin '86 DD |
pics?
1988 944 turbo |
Is the suspension adjustable? can you raise it up? What are the alignment settings? How much negative camber is there? A picture or two could certainly help.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Have your wheels got the correct offset?
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
