Need some electronic wiring expertise... (fuse/relay panel)
Hello, all!
Still working on the wiring in my '77 924 and could really use some expertise right now... I have taken the fuse/relay panel off, cleaned up the corrosion, replaced wires, and sanded connections, now i have put it back together, but there are 5 wires/connections present, that I have no earthly idea where they connect to. If anyone could please advise me as to where these 5 wires are supposed to connect to, it would be so very helpful. I believe all of my other connections are correct, except these. I will add some pictures of said wires/connections, as well as the back of the panel so that all is visible. Any help would be much appreciated! Thank you! Also, if anyone spots any other errors in my setup, please let me know! Thanks! ![]() ![]() ![]() ![]() ![]() ![]() ![]()
1977 Porsche 924 Martini & Rossi Edition |
try with the diagram to recognize all
Pelican Parts: Porsche 924/944 Electrical Diagrams every car have mistery wires that don't go anywhere(spare positive,grounds,options for other markets so try if all on your car works normally before broken your head. If you have problems i have a 80 924 and maybe is similar and can take photos
porsche 924 carrera gt 90% ready porsche 944 NA 86' half 951 951 full project for 944 chrysler 300M 6 x 924 and 944 canibalized or death |
77 924..clinton twp. mi.
the red wire with the plastic end go's on the right hand side of the front row or the male con.'s as seen in your pic...the black one ...dose it go to a glass fuse that is fix'ed to the under side of you dash..??the white wire go's in the back row left hand side next to the red one...
.(may the porsche be with you) |
it's hard for me to take pic's right now but here it one..mine is a 77 also..
old 924- I'm looking at the picture you presented (thanks by the way) and am trying to follow where you are saying wires are going, but am having a problem. It seems as if the picture you presented is contradicting what you are saying. Or am I just being retarded? Any clarification would be very much appreciated!
Also, does anyone else have any pictures of the back of their fuse/relay panel with everything plugged in how it should go? Or have anything to add advice wise? it would be much appreciated! Thanks!
there are 3 red wire's one in the back left and one in the front right and one in the front left the pic show's the 3 red wire's only your back left front and back left is plug'ed in and the white one go's next to the red wire in the left back .i will P.M you my # if you need to call and i can try and talk you thru it..if you want..dennis..
.(may the porsche be with you) Last edited by old 924; 06-04-2012 at 02:32 PM.. |
Oh, okay. I was being an idiot, and reading what you were saying wrong, lol.
And when you are talking about the white wire, it is white with a green (or yellow, cant tell) stripe down it?
yellow..
Gotcha!
(Thanks!)
im going to work on my car 2marrow..so if you need help ,when im under my own dash is the best time..you want my#..?? it's kind of hard to fit the computer under the dash with me there's no room as it is...lol
Haha! That would be great! I promise I wont bother you unless I run into a stump i just cant fit my head around! Heh
Still trying to figure out where wires 1, 4, and 5 are supposed to connect to (in my pictures). Any help would be much appreciated.
