Send a message via AIM to cbjars
suppousedly bad radiator?? Help explaining how it works
I supposedly have a bad radiator on my 1985/1 NA 944, and am seeking help determining if it is good or not. Car was not Overheating till a new water pump and thermostat were installed. I took it back to the mechanic to take a look at it and he explained the problem is most likely the radiator. After asking him alot of questions, he said there is no real way to till if a radiator is bad or not, which I do not believe. Is there any way to inspect radiators?
Here is the Problem: Car will overheat after about 7-8 mins of run time. If you rev the engine, coolant circulates and the engine cools down. After a few moments the engine will than start to overheat again.
What has been done / Tested:
Car has 82,000 miles, and the radiator shows a little wear, but not in terrible shape. Does not have any blockage. (took out radiator and water freely flows thro it)
Car has brand new water pump installed by professional import mechanic. old water pump was leaking slightly but would keep the engine cool. Also installed new thermostat (part# 234-192JV)
Air has been bleed out of the coolant system at least 4 times by me and at least 2 times by the mechanic.
new water coolant temp installed.
has 944 turbo fans installed and engine tested with both fans running.
Any Insight would help thanks.
Old 06-09-2012, 03:52 PM
Bleeding. There is still a bubble in there. Or, you have a blown head gasket. Put the front wheels on a ramp or on stands and try and bleed it again. I Don't think your mechanic is so thick that he would miss a blown gasket.
Old 06-09-2012, 03:58 PM
Toofah King Bad
Rasta Monsta's Avatar
In answer to your question, yes it can be tested for flow at a radiator shop.
BTW, what are you calling "overheating?" The temp gauges in these cars can be gloriously inaccurate.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-09-2012, 04:15 PM
Smoke coming from the engine lol.
Old 06-09-2012, 04:58 PM
Back from Beyond
Smoke or steam?
If car ran cool enough before water pump was changed then your rad's probably fine. I'd suspect air in system (as mentioned) and belt tension and/or the thermostat.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-09-2012, 09:16 PM
White and Nerdy
Tervuren's Avatar
Sometimes flushing the coolant system, can break loose deposits inside the engine, these get hung up in the tiny radiator tubes, and clog it up. I had a good radiator go to nothing after having had changed the Water Pump as part of a timing belt service. Complete clog up.
What do you mean by "smoke coming from the engine"?
Shadilay.
Old 06-10-2012, 09:59 AM
Good to know someone else had a similar issue to mind. As far as the smoke, when the temperature gauge in the car get hots you can see light smoke coming from the engine passenger side.
Old 06-10-2012, 10:57 AM
Originally Posted by Slam View Post
Smoke or steam?
Prob not air when it was bleed so many times. What is the correct temp for the thermostat? It looks like 80 degrees, but I think my mechanic put one it that is 90.
Old 06-10-2012, 10:58 AM
Proprietoristicly Refined
John_AZ's Avatar
It is an 80*C thermostat combined with a 75*C radiator fan switch for the early 944/1 series.
I run a cooler 71*C thermostat combined with the 75*C radiator fan switch on the '87 that heats up.
87 944 getting hot...
If you are too rough with the radiator and the flush used, you may damage/cause leaks between the rubber seal between the metal and the plastic on the radiator.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-10-2012, 12:06 PM
Volhv's Avatar
Engine passenger side smoke, probably unrelated. That's where the exhaust manifold is, so you might have oil leaking on them from the cam tower. Does the smoke eventually go away? (after oil is burnt off)
Old 06-10-2012, 12:45 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Did you turn the heater on high when you bled the system? If not, you have an air bubble trapped in there, and that can cause the over heating.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-10-2012, 01:08 PM
well it only happens when it is super hot.
Old 06-10-2012, 02:15 PM
This might be a problem. My AC doesnt work at all. Heat or cool. and it doesnt blow air. I do have the heater in the open position when i bleed tho.
Old 06-10-2012, 02:16 PM
White and Nerdy
Tervuren's Avatar
Does the switch actually move the heater valve under the hood? Its broken on my car, so I have to go under the hood. The heater core valve is behind the engine underneath your fly wheel sensor connectors, and above the clutch.
Shadilay.
Old 06-11-2012, 08:05 AM
It looks like it is opening and closing. Even so wouldnt the coolant still travel thro the block?
Old 06-11-2012, 04:13 PM
Old 06-11-2012, 07:28 PM
buying a new one would definitely solve the problem, but of course that would be too costly. your best bet would be by a test flow at a shop. and if it were problems with the parts there are tons of places there that sells radiator parts at a great bargain.
Old 06-22-2012, 01:34 AM
If your "professional import mechanic" cannot show you the factory service manual for the 944 or the factory timing belt tension tool for the 944, he is nothing more than an amateur with metric tools. Find yourself someone who really knows these cars and your problem is well on its way to being fixed...
Good luck, George Beuselinck
Old 06-22-2012, 04:20 AM
9FF 9FF is offline
9FF's Avatar
The problem is the thermostat you fitted to your car (part# 234-192JV) is an 89deg thermostat. Your model calls for an 80deg thermostat and an 85deg fan switch. The thermostat and fan switch work together to keep the car at the correct operating temperature, i.e: they are matched. The thermostat you have will make the engine run hotter as coolant is not allowed to flow to the radiator until a much higher temperature than stock.
You need to replace what your thermostat and fan switch with this: 944online.com - Water Cooling System Find Parts For Your Porsche 944 And Get Your Car Back On The Road.
Old 06-22-2012, 05:04 AM
SLED GUITARIST
Dan Himan's Avatar
Ouch the Forum host sells the correct thermo as well.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2
1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan
1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Old 06-22-2012, 10:51 AM
