Window Switch Assembly Loose?
http://forums.pelicanparts.com/uploa...1339282866.jpg
http://forums.pelicanparts.com/uploa...1339282933.jpg Is there a clip inside the door that I'm not seeing or is there some piece missing from both assemblies? When I bought the car both the switch holders were hanging off like that and when I replaced the switches they are a bit worse after I screwed them back in. If I push in with my hand they seem to fit in but then they just hang on their own. I'm puzzled since I've never seen a late model interior besides this one and I don't know how it's supposed to be. :confused: |
As the door pannels get older the majority of them are like that ,the trim doesnt seat properly anymore ,mostly because of the weak corners in which they screw. If the corners are weak you could try reinforcing them .
How should I do that?
The below link shows how to do the inside of the door cards to strengthen them.
DIY Inner Door Panel embalming - Rennlist Discussion Forums Cheers, Larry |
Thanks much!
The back of that switch panel should look like this, those metal clips go inside the door panelhttp://forums.pelicanparts.com/uploa...1339494747.jpg
Thanks for the photo. I fear the metal clip is missing on the edge. Have to go look again.
| All times are GMT -8. The time now is 06:19 AM. |
