944 differential troubleshooting
Hi all,
after posted for a banging sound when starting off, and after many hours to search ... I finally ask myself about the differential .... here is my first thread about my orginal problem http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/686292-944-163hp-banging-when-starting-off.html and I found this thread, the only difference is that the clunk appears only during acceleration : http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/547336-differential-problem.html I checked the clearance of the part with the red arrow and I have clearance in radial direction (very small) and in axis direction (much more), is it normal ? is this clearance could cause a banging sound ? http://forums.pelicanparts.com/uploa...1276189521.gif So, do you have experience about noise caused by the differential ? a differential bearing could cause a bang when starting off ? I'm a little bit lost, and I found lots of post about "rear clunk" on 924/944 ... :( but never a real solution .... thanks in advance |
| All times are GMT -8. The time now is 04:47 AM. |
