944 differential troubleshooting
Hi all,
after posted for a banging sound when starting off, and after many hours to search ... I finally ask myself about the differential .... here is my first thread about my orginal problem [944 163hp] banging when starting off and I found this thread, the only difference is that the clunk appears only during acceleration : differential problem I checked the clearance of the part with the red arrow and I have clearance in radial direction (very small) and in axis direction (much more), is it normal ? is this clearance could cause a banging sound ? ![]() So, do you have experience about noise caused by the differential ? a differential bearing could cause a bang when starting off ? I'm a little bit lost, and I found lots of post about "rear clunk" on 924/944 ... ![]() but never a real solution .... thanks in advance |
