Send a message via ICQ to Kandid
Question Swepco 503
I just received a Swepco 503 and direction on the bottle are not clear, what's the best way to use it on my 84' 944NA?
thanks
Old 05-15-2002, 08:42 AM
AFJuvat's Avatar
You put it in your gas tank.
AFJuvat
Old 05-15-2002, 02:38 PM
Deeks's Avatar
huh ?
Over here in England we use the stuff to wash the windscreen with.... has a great clean finish, repels raindrops too !!
Old 05-16-2002, 04:20 AM
it's already in a gas tank
don't feel any difference though
Old 05-16-2002, 06:47 AM
AFJuvat's Avatar
Swepco 503 is a fuel injector cleaner.
AFJuvat
Old 05-16-2002, 06:52 AM
Deeks's Avatar
I used some injector cleaner a few weeks back in an attempt to clear up a slight engine stutter I could feel and hear when idling and under very gentle acceleration. Didn't feel any difference at all, and it did no good, so I deduced from this that it's probably an electrical problem of some sort?
Must do something good in the long run though....
Old 05-16-2002, 07:19 AM
What year model do you have deeks? Could it be the infamous 944 engine shudder? Try doing a search for that.... my car has "the shudder" and it can be fixed by upgrading the dme computer... it's a few hundred dollars.
Pat
Porsche man for life.
83' 944
97' Yamaha FZR 600 SOLD!!
02' Suzuki GSX-R 600
Old 05-16-2002, 09:17 AM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
In my experience, I have found that Fuel Injection cleaner basically does nothing. If you run it in your car when the injectors are already clean - it helps keep them that way - but if the injectors are dirty enough to make you think about buying the cleaner - it never works.
Think of it this way. If you have a bathtub full of water and put in a couple of glassfulls of Vodka - will the bathwater taste like Vodka? No.
There is some liquid "system" that cost about $100 that will work. I had REALLY dirty fuel injectors on my Sidekick. Put a bunch of expensive cleaners thru the engine - nothing. Then I took it to this place and they put liquids in just about every hole I could see in the engine and BAM - the car worked like it had a new engine. They used this "system" I'm talking about.
944S Boyeee
Old 05-17-2002, 11:49 AM
