I used the Lucas brand snake oil on both my cars and it didn't do dick
the primary difference in oils, is the cold viscosity. remember an engine wears most before its warm? this is because the oil is not up to temp and is not lubricating properly. so the thinner you oil is at cold temps, the more it lubricates (remember flow = lubrication), and the better it is for your engine. synthetics are made differently then dino oil. dino oil is made with the thicker grade of oil (20w-50 is made from 50wt), with certain additives to get the cold properties of 20 wt. synthetics are made with the lighter oil, with additives and chemistry to keep it thin up at high temps. this is why synthetics are so much better at cold temps and at startup then dino oil, because its so thin. synthetics are always better, period. |
Thread is very off-topic...
Not sure what your position is in the Industry but you can write all you want about new technology being the saviour for all things however there are many accounts of worn parts due to running these lighter oils in our cars. Flow is NOT the be all and end all. Oils do not resemble each other at engine temp or hotter. The thicker dino oils at least have some form of film strength at heat. Your beloved hi-tech low visc oils are like hot water at those temps. When you need the most protection against all the mechanical parts that are trying to separate themselves at high speed from the engine case, if you don’t have film strength you will quickly learn the pitfalls under high loads. If so many problems occurred due to cold start lubrication (or lack of it), why, when we were all using thicker dino oils, weren’t cars failing all the time with over rapid wear rates? Answer…they weren’t. It was only when M1 lowered their ZDDP content without telling anyone that all of a sudden there were cases of accelerated wear all over the world. This, is real world science, not test tube bench race forum splatter.
You're wrong - BUT the correct weight of synthetic oil IS and always will be better than equivalent dino oil. Fact. It's just not for any of the reasons you stated. |
Holy crap it's a full on oil thread!
um, so.........................
does this stuff work? |
oil is backwards from perception. so many people are freaked out that oil get thin with heat ... this is basically a non-issue. you want that. the trouble with oil is that it is to thick at anything other then operating temp. |
Interesting, I was expecting a few footnotes regarding the above theories.
I always thought thinner oil lubricated certain things better (rings, valve guides, wrist pins) and certain things worse (rod and crank bearings). Engine power is more affected by the valve guides and cylinder bores than by the worn bearings. Loose valve guides and loose piston bore will lead to loss of compression so you wnat an oil that flows in these areas. Therefore thinner would help retain engine power as it gets older (as long as the bearing don't wear out and you still have oil pressure). But I don't track my cars, either. |
10/24/2010 MotorMouth Join Date: Dec 2009 Location: Granite Falls, NC Posts: 338 Car: 1992 Camaro RS Engine: 305 TBI Transmission: T5 "Re: Any personal experiences with "stop leak" products??? -------------------------------------------------------------------------------- In my experiance Stop Leak has caused me to have to replace 3 waterpumps. Two on my cars and one on my Mothers car. It is really meant for emergency use only. All three times the pumps went out within 2 - 4 months after using it. So from now now on if I have to use it as a last resort to get home or to a shop I will. I will then drain it ASAP! |
You lost me at oil is backwards from perception.
My daily driver 1994 toyota camry developed nasty oil leak.used ATP RE SEAL AT205 WAS LEAKING ABOUT A PINT A DAY,AFTER ABOUT A WEEK IT STOPED LEAKING ,HASNT LEAKED AGAIN,ILL USE IT IN THE CAR AGAIN WHEN I CHANGE OIL, I DONT NOW IF I WOULD USE IT IN MY PORSCHE ,BUT WORKED REALLY WELL FOR MY TOYOTA,FOR WHAT ITS WORTH,GOOD LUCK TonyG
Glad to hearit healed the Yota.. When did you put in the sealant? |
race cars use straight oil because 1. they run at higher temps then we do, 2. they run longer and harder then we do (thats what she said) 3. they change there oil at less then 1000 miles 4. once they are started they are run until they are rebuilt (basically) .... etc etc etc a racing situation is a very different one from street driving, or being stuck in traffic or nearly anything we do with out cars, so its not a good comparison. of course oil pressure goes down when flow goes up because of thinner oil. if it drops into the warning zone, you have gone too far. i do not recommend that. i run 20w-50 full synthetic and don't ever see my pressure drop below 3 bar at idle, even when autocrossing/road racing. |
Wow, I opened up the flood gates with this one. Seems to be a lot of different points of view on oil. At least I know NOT to use the stuff I originally asked about. I'll take all the points about oil into advisement.
I'm using Mobile 1 10w-40 in my both my 85.1 & 86 Turbo. I got a nice leak from the oil pan on my Turbo. |
10w-40 and 20w-50 both work great for me... my first 944 was dino and the second uses synthetic. Haven't really noticed a difference.
| All times are GMT -8. The time now is 08:28 PM. |
