headlight flicker
Headlights have a bit of "flicker" when stopped at idle.
Any suggestions? 86 951. |
AFM #725
...cleaned the grounds? Lol or perhaps the wiring
How much of a "flicker"? One that catches your eye, or one that you have to look for to see? It could just be the engine is changing RPM slightly, causing the alternator to charge more/less.
Jonah Boyd 78 928 5 speed - #111 81 928 5 speed - the "Copper Turd" 81 928 Auto |
it catches my eye.
Probably a bad ground, Or your alternator is having issues.
Self-Proclaimed Newb
I have the same problem. And my horn (recently replaced) doesn't work. Same bad ground maybe??
Current: 1986 944 Turbo - Sapphire Past: 1983 944NA - Black (RIP) 1985.5 944NA - Guards Red (in purgatory) 1985.0 944NA - Maraschino Red (traded for a Volvo 244 )
