Peach Parts spy...
RamahX's Avatar
Polished Intake is different, help
'84 944 n/a unmodified
PO gave me a polished Intake Manifold. I have my current one off to do the fuel line upgrade and some other items.
Unbeknownst to both the PO and I is the polished Intake does NOT have a large vacuum nipple below where the Throttle Body mount. Also there is a hole on the side that is NOT there on mine.
Searched PAL and cant find these numbers stamped on manifolds:
Current manifold 944.110.151.6 R marked 83
Polished manifold 944.110.151.6 R marked 82
Can I reroute vac lines to use the side hole on the new manifold instead?
Pictures:
Mine on the left, new polished on right, note mine has vac nipple to venturi:
Mine with bottom vac hookup below Throttle Body mount:
New without bottom vac hookup below Throttle Body mount:
Mine with undrilled side hole (left recess):
New with drilled side hole (left recess):
My engine so far:
'84 Porsche 944 N/A ~ 150 of the brattiest horses EVER
'87 MB 300SDL aka Vedith (silent v)
'94 MB E320 wife's daily driver- until she STOLE my 300SDL
'87 MB 190E t-boned, saved daughters life
'86 BMW 535 - sold : (
Old 07-31-2012, 07:58 PM
Volhv's Avatar
Hmm, must be an early vs late thing.
You could always just polish the original one, it's easy....
No it's not. I tried, and gave up. Too time consuming if you don't have a spare that can be done at leisure. Ended up sandblasting and scotchbriting, turned out pretty good.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-31-2012, 11:57 PM
The vacuum should be the same throughout the manifold, so you could use the side hole.
Not sure there is enough room unless you can get and elbow nipple with the correct diameter.
You will have to re-route the hoses to fit the side nipple. You will probably have to
fabricate some new hoses.
Clifton
Old 08-01-2012, 05:58 AM
Toofah King Bad
Rasta Monsta's Avatar
Numbers are "casting" numbers. Sadly, they don't correspond to Porsche part numbers.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-01-2012, 04:23 PM
I believe it's an a/c vs. non a/c thing, but don't quote me on that. Just get creative with the vacuum lines if you really want the polished one.
Old 08-01-2012, 07:02 PM
Peach Parts spy...
RamahX's Avatar
Got it sorted. Got a $2 heater hose elbow and epoxied it in there, then ran heater hose to the venturi. Works! Cranked up and runs like a champ.
Here it is:
And the side vac fitting I made:
Old 08-02-2012, 07:40 PM
Dave Colangelo's Avatar
Just a word to the wise, check that epoxy joint every week or so for the next month if you are going to be using the car. Many epoxy's especially the ones you find at places like home depot and such are not made to handle much above room temp. The engine bay can be a hot place and may lead to the break down of the epoxy or it may not. I try to avoid using epoxy and glue around my engine in fear of it melting or catching fire. The polished manifold looks great though!
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 08-03-2012, 09:54 AM
Banned
Yeah you really should have used jb weld in there, I don't trust that blue or clear stuff much at all.
Old 08-03-2012, 12:17 PM
Peach Parts spy...
RamahX's Avatar
Used JB, thats some blue silicone I put in there temporarily to test the engine to see if it even ran. Once I confirmed all is well, took it out, cleaned, and reinstalled with epoxy.
Right now Brian944turbo in SC is looking for a steel elbow out of an early intake, and I'll install that to make it more permanent.
Old 08-03-2012, 12:48 PM
Peach Parts spy...
RamahX's Avatar
I must say tho, in all my 50 years I've never heard of JB Weld, epoxy, or silicone gasket sealant catching fire...
Old 08-12-2012, 06:15 PM
