8 inch Cup 1 wheels fit on front of S2?
Can I replace the 7 inch Cup 1 (968) wheels on the front of my 89 S2 with 8 inch Cup 1 wheels without clearance problems. The front tire size is 205 55 16. I will space the rears (8 inch with 225 50 16) out 20mm to help compensate for change of front track.
Thanks. Joe
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles Last edited by jhowell371; 03-26-2014 at 12:39 PM.. Reason: grammar |
968 C2 Turbo wheels (commonly misnomered as Cup 1) are 7.5" wide with an ET of 65.
the 911 version of the C2 Turbo, from which they originated, was 7". not sure what the ET was. the replicas have a different offset, and stick out about 5mm more. unless you don't care about acceleration or braking, i would not space things out that far. the added weight will be very noticeable. each of the rears will go up a whopping 4#. |
These are the wheels in question. Front 7 inchers weigh 17lbs. 2 oz. the 8 inchers weigh in at 19lbs. 11 oz. The stock D90s weigh 19 lbs. even for the 7s, the 8 inchers come in at 20lbs. 14oz.
![]() I dislike the looks of the center spokes sticking out past the edge of the rim on the 7 inch fronts so replacing with 8s is for looks and my satisfaction only. These wheels in 8 inch form weigh only 11 oz. more the 7 inch D90s. Wish I could use the 7 and 8 Fuchs I've got stashed
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles |
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Pic of my 968 with Cup I 17'' & tires combo mention above.
the 7" wheels in the 16" have a 55mm offset
the 8" wheels have a 52mm offset. that will push the outside edge of the front rim outward by 9mm (3 for the offset and 6 for the extra 1/2" of the 1" wider rim) |
All this gets me to thinking maybe I should just leave it alone as Porsche made it
aaacckk!!!! that's what i get for starting drinking at 3. yes, 15.7mm.
