mcavour's Avatar
A/C blowing hot air...
Got an anoying issue with my a/c momentarily blowing hot air upon acceleration. It only does it for a few secs, usually upon starting from a dead stop and on a fast take-off... Afterwards it blows cold air again, what gives??? PS: The system blows hot air upon accel when a/c is off too!!! (fan also off...) If anyone cqan shed a light I would appreciate it! Thanks in advance.
1989 944 Grey/Linen lthr
Old 05-30-2002, 11:26 PM
When you let off how fast does it return to normal? Immediately or does it take a few seconds?
Old 05-31-2002, 05:59 AM
mcavour's Avatar
It takes a few seconds... No more than a minute though, but even after it is blowing again, it takes a few sec for the temp to get cold again...
Old 05-31-2002, 01:24 PM
Doesn't vacuum control the heater valve in front of the firewall?
Old 05-31-2002, 03:25 PM
AFJuvat's Avatar
I'm taking a shot in the dark here, but, I always try the simple/cheap things first...
Check your alternator/AC belt for proper tension and/or excessive wear. If your belt is loose and/or worn, you may not get the compressor spinning as quickly as it needs to be, until it has time to "catch up" - Especially since you say this happens when you go from a dead stop to a fast take-off.
Can you duplicate the problem with the car standing still? Does it do it at any other time?
Beyond that, there are quite a few causes - some easy, others ugly. Need some more details to troubleshoot this one properly.
AFJuvat
Old 05-31-2002, 09:27 PM
