KLR Diagnostic Port - no voltage
I built the blink code LED that's specified in may threads. However, when I plug it into the KLR diagnostic port, in the correct position, it does not light up. I've tried this after driving the car around for a while and before shutting it down. The LED I have tests good when I do apply voltage to it. The KLR port does not show any reading, beyond 0.1 Volts, when tested with a Voltmeter.
Could it be that my KLR is trouble free! The throttle sensor plug is kind of a b**** to pull on the turbo so I didn't try that.
Old 11-08-2012, 02:22 PM
