Yan Yan is offline
Unstable idle and fluctuating gauges?
Hi!
For about 1 month I've had stability problems with my 951. Especially when the car is hot, the idle is much lower than it is on colder days (about 550-600 RPM vs 850-900 RPM). Also, the idle isn't stable at all. It can not linearly fluctuate by about 100 RPM, similarly to a old 454 engine.
I also noticed that since I have this problem, my oil pression and batt. voltage gauges sometimes fluctuate abruptly, but after this fluctuation they return back to the correct position.
Can it be the DME or something like that? I sincerly have no idea...
Thanks alot
Yan
Old 06-04-2002, 12:09 PM
