-   -   Strange noise around drive line while idle (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/705927-strange-noise-around-drive-line-while-idle.html)
84 944 oneowner 09-15-2012 08:34 PM
After my 944 has been driven some and warmed up, when i disengage the the clutch amd put in nutral i hear a odd noise from under the car somewhere from shifter to rear end. It doesn't make this noise when until its been driven around. Any help would be much appreciated. Thanks hope everyone has enjoyed your so so warm and not so wet summer lol.
Gawernator 09-15-2012 09:35 PM
Could it be something exhaust related? wild-guess. I had a rattling exhaust that would randomly make odd sounds
Guest765 09-16-2012 04:13 AM
Throwout bearing or exhaust
84 944 oneowner 09-16-2012 07:22 AM
Thank you all for your suggestions! I was also afraid it could be the throw out bearing too. I believe i may have dried it out when my clutch disc got stuck. Only after i replaced the master and slave did i find out lol. Well would anyone happen to know if it can be regreased by chance?
968 GUY 09-16-2012 07:49 AM
You will have to remove it either way (not really regreaseable) just replace it.
Guest765 09-16-2012 08:38 AM
I regreased my throwout bearing but it was a bit of a pain.
Also i was just thinking and this could be your torque tube bearing also. Check clarks garage for how to check and test.
Gawernator 09-16-2012 09:01 AM
I don't think the TT bearing would make idle noise. Mine doesn't. Only a little under load
Guest765 09-16-2012 09:41 AM
Torque tube could absolutely make noise at idle with the clutch engaged because its still spinning
Gawernator 09-16-2012 11:45 AM
I see
84 944 oneowner 09-17-2012 05:39 PM
I gotcha! Thanks a million. But when the clutch is engaged the noise "light cluncking" goes away. When its out of gear is when i hear it. But not all the time that's what's making me scratch my head some. Thank you all so much for the input!
Guest765 09-17-2012 05:46 PM
When i say engaged what i mean is clutch out and in neutral. When you press the clutch to the floor the noise goes away is what im getting from your post. If the noise goes away almost instantly after pressing down the clutch pedal then its almost definitely the throwout bearing. Mine does exactly that and as far as im concerned its harmless.
Anecdotally ive heard a brand new throwout bearing has ended up being even louder than the old one for some people on the forums.
matty89 09-18-2012 03:03 PM
it could be the TO bearing or ur TT bearings :) only way is to ur a stetoscope :) on TT or Clutch housing
Gawernator 09-18-2012 04:20 PM
I could be wrong. But I would think it's more likely the TO bearing then. Because the TT bearing would probably make noise under load.
Guest765 09-18-2012 09:36 PM
Gawernator got it right.
matty89 09-20-2012 09:36 AM
Only way is the listen maybe it's both keep us posted good luck man
kmakovac 09-20-2012 11:06 AM
torque tube 90 %
i rebuild myself about 4 of this.The maximum noise is at idle(the car dont have noise from wind and heard better) and on deceleration-pedal gas release like a zzz-zzz-zzz-zzz or ratle-ratle-ratle... in every gear but in the first two better to heard-i think the same reason-wind.
is a big procedure for rebuild and a little tricky but if you do a clutch job is hight racomanded,you will need from 2 to 4 hours to rebuild it
Rasta Monsta 09-20-2012 01:34 PM
I am leaning toward TT bearings. Easy to test. If the throwout were noisy, light clutch pedal pressure (running, in neutral) should make the noise change. If not, torque tube.
